Delphi MAF
So looking under the hood, it seems the maf is a little bigger then I think it should be. Not sure if it's stock or not though, it has Delphi stamped on it. I take it this isn't a stock maf for the 6.0 is it?
Are you having problems? What do you mean by bigger? If it still fits in the diameter size of the intake tube then it should be good to go. I do believe Delphi is indeed the stock company for the MAF but that doesn't mean someone didn't replace it with a unit from a different engine setup.
No problems, the previous owner installed a intake and just trying to see if they upgraded the maf as well.
The MAF is stock and is capable of flowing for up to somewhere around 500 HP
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
