TSB sources
which one do you need?
I have a few in word format
I need one referring to the seat belt retractors.  I had read that there was one regarding a recall.  I think the number might have been 00-02-35-00045.  (I could be wrong on the number.)  Is there a site that I can do a search of TSB's?
I'm having a problem with the driver's side seat belt retractor making noise, squeaking and being extremely annoying.  The noise is more obvious when it's cold out.  Of course now it's warmer and the dealership is refusing to do anything about it.  I wanted to see what the TSB or recall referred to and if there was any ammunition I could use to get them to take care of the problem.
Thanks for your help!
www.alldata.com lists them but has no details (you have to pay for that)
see if you can find the correct #, these are all i could find...
 #99-07-30-024 Driveline Vibration/Growl Noise (Reprogram PCM) - (Oct 18, 1999)
 #99-08-45-005 Accessory Receptacle is Inoperative (Check Aftermarket Device Plug) - (Nov 8, 1999)
 #00-06-02-001 Engine Runs Hot, Overheats, Loss of Coolant (Polish Filler Neck/Replace Radiator Cap) - (Jan 5, 2000)
 #99-06-04-047A Metal Contamination in Vehicle Fuel System (Clean Fuel System) - (Feb 9, 2000)
 #00-06-04-014 No/Hard/Slow Start, Backfire/Kickback (Replace Crankshaft Position Sensor) - (Mar 28, 2000)
 #00-07-30-006 Stall/Surge at Stop or Shifting to Drive/Reverse (Install Updated Calibration) - (May 3, 2000)
 #00-06-01-014 Tech - Possible Oil Filter Damage or Oil Leak from Oil Filter Area - (Jun 1, 2000)
 #00-08-51-001 Outside Rear View Mirror Housing Turns Chalky/Dull (Color/Clear Coat Mirror) - (Aug 25, 2000)
 #00-06-04-042 Malfunction Indicator Light (MIL) on with DTC P0446 Code Set (Reprogram PCM) - (Sep 29, 2000)
 #01-07-29-001 Manual Transmission Comes Out of Gear (Install New Shift Shaft Lever) - (Feb 13, 2001)
 #01-07-30-002B Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Third Gear, Instrument Cluster Inoperative (Replace Ignition Switch) - (Apr 30, 2001)
 #01-07-30-021 Park/Neutral Position Switch Connector Cannot Be Removed (Replace Switch and Connectors) - (May 2, 2001)
 #99-01-39-004A Air Conditioning Odor (Install Kit) - (May 22, 2001)
 #01-08-56-004A Security Lamp Illuminated on the IP, Engine Stalls, No Start, DTC B2960 (Security System Sensor Data Incorrect but Valid) Set (Inspect and Repair Cause of DTC B2960) - (Sep 13, 2001)
 #01-06-04-037B Fuel Transfer Pump Inoperative (Replace Fuel Transfer Module) - (Oct 16, 2001)
 #01-06-05-006 Exhaust System Rumble/Rattle Noise (Replace Exhaust Pipe Seals and Modify Exhaust Pipe Ring Flanges) - (Nov 2, 2001)
 #02-08-64-016 Front Door Hinge Pin/Bushing Wear, Front Door Sags or Door Chucking Movement (Service Procedures, Teflon bushings/Severe Usage Service Kit Released) - (Jul 19, 2002)
 #02-06-03-006A No Start, No Crank, Battery, Batteries, Generator, Gages, SES, SIR, Brake, Security, Theft, ABS, Hot, DIC Messages, Lamp, Light, Battery and Generator Diagnostic Testing, and Cadillac Roadside Service - (Nov 26, 2002)
Thanks guys, for all the help.  I didn't find the TSB I was looking for, but did find a list of TSB's on alldata.com as suggested and also some on the NHTSB web site.  If I do some more digging...
This is a great site!  I appreciate it and you guys for helping!
My 2000 had this same problem.  The seat belt was replaced with no questions asked.  I was told that there was a large number of others that were in my boat.  It had to do with the new 4 door extended cab and the seat belts being moved to the seat from the door pillar.  Good luck on finding the TSB#, I will look through my paperwork to see if it is listed on it.  I know for a fact that the problem existed though.
just found my paperwork from this problem.  I don't think it list a TSB number unless I am missing something, but here is what it says
A LEFT SEAT BELT RETRACTOR CONSTANTLY SQUEEKS WHILE DRIVING.  INSTALL S/O PART
CAUSE:  RETRACTOR SQUEEKS
           140 QUICK SERVICE 15A- MISCELLANEOUS
                157   W40
           1    12477919  BELT KIT
REPLACED LEFT SEAT BELT RETRACTOR
That is all my receipt says.  Don't know about that 157  w40 number.  Hope that helps
157 W40 is probably a dealer code where they charged $157 to spray your seat belt with WD-40!  Just kidding.  Anyway, I had my 2 front seat belts replaced via a recall, but my receipt doesn't list the recall #.  They replaced 2 Belt Kits part #'s 88935285 & 88937153.  I'm not sure what they did, but I know they moved all my tools around that I had  in the back and didn't bother putting things back the way I had it.
The dealer said there was no TSB on this particular problem.  So far they have said they were told by GM not to replace anything unless the seat belt doesn't function properly.  They said the noise would just come back after another year or two.
After I complained even more about how loud the squeak is at times (worse when cold and low humidity), they agreed to try and duplicate the conditions and see if they could do anything.  They've had it for two days now and they haven't even returned my call to tell me what is going on.  I'll post what ever my final results turn out to be.
Only one person at the dealership said he had seen this before, and the retractor would need to be replaced.  Another said they were only doing the replacements on Cadillacs with this problem.  Funny how someone buying a Chevy gets sub-standard service compared to someone buying a Caddy.
now that you mention it when it is cold outside (below 20) my seatbelt makes a loud squeaky annoying noise.  It didnt happen as much this yr as it did the yr before.  I totally forgot that i had this problem.  I just let it pass but i agree with you it is annoying
I've got seatbelt issues as well.  Had the recall done due to the retractors.  I've had a squeak in the driver's belt while leaning forward or back.  It went away for a while, but now is back.  Being that they've worked on it/looked at it several times, I may take it back and complain.
Well, the dealer said they couldn't duplicate the conditions to make the noise.  I think it is a combination of humidity, temperature, and wear that cause the problem.  Since it's warming up and there is more humidity, the problem will probably mostly go away until this winter.  I'm guessing the plastic in the rollers dries out over enough dry days, which happen more in the winter time, and then start squeaking.  I'll be out of warranty then, but the dealer said if it gets bad again this winter, they'll go to bat with GM for me since I came in to try and fix the problem before the warranty period expired.  Crossing my fingers...
Lets see how quick they respond if the part fails and you end up in the windsheild!  I always thought that they had to fix any problem with the seat belts?  A saftey issue.
    250.3k
    Victorlani
    Victorlani
  • Who's Online   1 Member, 0 Anonymous, 354 Guests (See full list)
