I would like to know how this is holding up as well. Mine is currently at the dealer with the same issue. They cant seem to find the "leak"
Had my truck about 3 weeks & had a wet passenger floor in front after a storm. Couldn't find anything leaking while pounding the truck with a hose. The dealer found the source of the leak at the same location mentioned By Z71 Blackout. They had to remove the fender & sealed up where a wiring harness & rubber grommet goes into the firewall. Looking at before & after pictures from the dealer, my wiring
harness was not sealed at all out of the
factory. It's been about a month since getting the truck back & so far has stayed dry inside after rain.
Here is what I found after a little investigating. Seems to be coming from a broken body weld behind the dash. Will be making a trip to the dealership tomorrow!
  • 2 years later...
  • 5 years later...
Have a 2015  Silverado with similar leak issue. Preparing to take the the fander off to reseal any and all seams if I find the same results as above videos.. Would appreciate any info that can be provided....
