2.5 Rough Idle when cold
Anyone with the 2.5 have an issue when its idling, in park or drive and it feels a little rough and seems like it has a miss?
took it once and they said it was just the way emissions worked on it (yea thats a lie).
Started it today and was letting it idle and revd it up to about 1700 and its popping out the pipe. To the dealer tomorrow.
I would complain and if they give you the same answer go to a different dealer.and call GM Customer support
So the dealer said they couldn't reproduce. Went and sat in the truck with the head Forman and reproduced it. They said the data stream shows good and that they have had some issues with the smaller direct injected motors having this issue
They are going to open a TAC with GM and see if they can get ahold of another Colorado to compare with.
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
