Caterpillar Plant Tour
RyanbabZ71
Yesterday we had an ASME conference tour in Lafayette.  We took a 2 hr tour of the massive (4 acres total only 2 being used) caterpillar engine plant.  These things are huge.  it is awesome to see something so massive being assembled.  The pistons on their largest engine is about the size of a 5 gallon bucket.  Also they make a V-8, V-12, V-16, and V-20 (and some inline 8s and 12s)
In 1983, Caterpillar opened the doors of the 1,500,000 sq ft (140,000 sq m) Lafayette, Indiana plant, which manufactures the largest diesel engines Caterpillar has ever produced, the 3500 and 3600 Series Diesel Engines. The 3500 Series covers a horsepower range from 600 hp (448 kW) to 2200 hp (1641 kW), and the 3600 Series goes from 1900 hp (1420 kW) to 7,300 hp (5450 kW). Both diesel and spark ignited versions of each engine family are manufactured at Lafayette. Caterpillar is the world’s largest manufacturer of gaseous fueled engines. (Natural gas, methane, propane, etc., also refered to as spark ignited engines.)
Id love to put one of these in my truck  :banghead:
Cool, sounds like fun.  I've toured a John Deere plant a few times, it was pretty cool too :smash:
BTW: post 2000 for me :banghead:
Info:
Well this was for an ASME (american society of mechanical engineers) conference.  It cost me $35 (for the conference, tours, shirt, lunch)
From what i gathered they only do tours to like student organizations and customers.  he said they do alot of tours for their foreign customers.  I have no idea how to set one up.  Id imagine it wouldnt be easy
I would like to tour the Super Duty factory in KY or the IH plant.
I applied for a job there last wk (kentucky plant)
(However i wont be trading my truck in for a ford ) :banghead:
clk7711 - Do you work for a CAT dealer??
No, I work for a big contractor who runs mainly CAT equipment. Over 150 different machines. I work in the maintence dept and love working around heavy machinery. Only a Hitachi excavator can compete with a CAT. :banghead:
Glad to hear your support for CAT. I worked for Cummins Corporate for 7 years, but last year moved and took a job as a Foreman at a CAT dealer in the component rebuild facility for the Machine Division (Heavy Equip). I'm still learning a lot about the machines and CAT specific things, but it's awesome to be around that stuff on a daily basis.
Those big diesels are pretty impressive!!!
However, since I have been building these things for almost 15 years, the novelty has worn off...  :banghead:
what i thought was very impressive also was how many used engines they had (broke down ones which dealers returned to cat).  They are all taken apart inspected.  Many parts are thrown away and what is reused is thoroughly cleaned.  Then they put it back together mainly with brand new parts and they are resold at about 3/4 of the cost of a new one (but basically it is a brand new hand built engine).  They had a bunch of them in the plant (couldnt even tell how many).  Alot of them were pretty new (less than a yr old) but looked like they were 30 yrs old.  Most are ran 24/7 till they die.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 774 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
