09 2500 manual seat upgrade
klawton
My father just purchased an 09 Chevy 2500 and it has manual seats. He would like to install power seats and I was wondering if the wires would be under the seat already that I could just purchase a power seat from a salvage yard and bolt it right in? Has anyone ever tried this?
My 2010 Sierra SL does not have the wires under the seat. Which trim level is his truck? I am certain that I could not even get power seats in the SL. The SL is a W/T with power windows and door locks (called Nevada Edition) and chrome trim around grille. Chevy trucks use a different designation for the trim levels, but the logic is the same.
The truck is an LT. There is a plug under the seat that has several wires coming in and only to going out to I believe the seat belt. I wasn't sure if the other wires would be for the seat.
My truck came with bench seat, and the centre seat was different to what the SLE got. SL seat has a fold down arm rest that does not have a lid, it just has a pocket and three cup holders for the 2 people that can fit in the front seat with arm rest down. The SLE centre seat has a storage area on top of arm rest under a lid, and the seat portion of the seat lists up to expose a storage area, that also has power port.
Reason for all that above is that I changed the centre seat in mine to the SLE one, and the power outlet supply wire was already in the harness and plug was under seat. Don't understand Chev trim levels on the trucks enough to know what the LT is.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
