2015 GMC Sierra
MaxTow 2015
Well, I sold the Silverado LTZ and ordered a 2015 Sierra 1500, 6.2L- 500 miles later...the reduced power indicator warning came on and now waiting on a new computer to be installed.
1st time the dealer said he has seen this before 35,000 miles. Anyone have this issue?
