2014 Silverado stock air box 5.3
Have the stock air box off my 2014 Silverado 5.3l with all fittings and hoses. Was taken off at 6k to put my Airaid system on. Not sure what its worth, so make me reasonable offers. I will ship for free to the lower 48 states. I will post some pictures later on today when I get off work. I'm located in Tulsa, OK. Feel free to PM me with questions.
  • 1 month later...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
