Electrical Issues in 2001 gmc sierra need help
I
My son has a 2001 GMC Sierra std cab short bed with a 5.3 L
We are having issues with the fog lights, DRL, and A/C.
I have checked all the fuses plus replaced with new just to be sure, we have also replaced the relays for all also. If I pull the relays and use a jumper wire across the terminals I can get them all to work but when I re-install the relays either new or old nothing works. I have replaced the head light switch and this did not fix the problem with the DRL either.
Any thoughts and ideas would be greatly appreciated. Thanks
We have installed new factory replacement fog lights, all fuses are good the only thing I see is the push button for the fog lights has a small light next to it and nothing happens when the button is depressed or pushed.
The DRL lights stopped working two days ago, I have checked the fuses and installed a new head light switch and they do not work. All other lights work fine ie: turn, park, tail, head.
the AC is the same as the others, I can pull the relay and jump across terminals and they all work if I do this.
He said the relays don't work but when he uses a jumper across the pins everything works. The relay sockets getting ground etc from ECM. I think that is where the problem is. A scan would tell.
