Call to Arms
EnergyFX
Thanks for the compliments fellas.  I'll be working on a couple more layouts soon.  College courses are taking up too much time right now to put forth any productive effort on them.  Trying to get to the Officer side of the military pay charts... then I'll be set!!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
