Surrounding Trim around Tow Hooks
Does anyone know the part # for the surrounding trim around the tow hooks? my SLE has black trim, but I want to change it out to the ones on the SLT and Denali (chrome??)
  • 2 months later...
I also would like to know this. Also since the piece I have doesn't have the hole for the tow hooks I'm curious if I could replace it with the one that does... Just in case for the rare occasion I need to put a tow strap on it.
Sorry! Found this in another thread.... gm-trucks
As for the Part Numbers these are the ones for the Chevy... not GMC but maybe it will help get you started.
22944881 is the black filler piece with the holes for tow hooks
22944882 is the chrome (plastic) piece
I think you're looking for the whole "Skid Plate" Right? It's part #3 in the attached image. If not, then you're probably talking about the "Hole cover" which is part #6.
Part# 22902312 Skid Plate (ANTHRACITE) Gmc, Trim components, w/o Denail Grey
If not, you can see all the parts associated with front bumeper here: http://www.gmpartsoutlet.net/auto-parts/2014/gmc/sierra-1500/slt-trim/5-3l-v8-flex-engine/body-cat/bumper-and-components-front-scat
GMC Sierra Front Scat
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 611 Guests (See full list)
