2" Level kit
Before measured 36-3/4" and now measures 38-3/4" and the rear is 39
what kind of kit is it?
i had a rough country on my 13...it definitely changed the ride quality it was much stiffer.
im hesitant to get it again or go for the bilstein adjustable shocks!
did you notice any difference
It is rough country. Ive done it on my 07, 11 and now my 14. No ride quality difference I can tell in any of the trucks.
nice....
i liked the quality of the kit but my front end felt very stiff after i installed the spacer on the bottom and the top. i was thinking about just installing the bottom this time...
Looks nice. Is it a 2 or 2 1/2 level kit? I thought they made a 2" front lift by itself and the 2 1/2 (2 1/2 front/ 1 rear) level kit. I put the 2" front lift on and thought it sat too high in front or too low in rear. So, I called and ordered just the rear lift from the 2 1/2 level kit.
It's just the 2" RC kit that mounts under the front strut. I did a measurement before and after and it raised the front 2". Now the front sits 1/4" lower than the rear. What did the rear part cost you?
Can you measure the thickness of the block?
I have a Zone block, that supposedly lifts the front 2". It is 1.125" thick. I'm curious if Zone got the dimension right.
$57 shipped from rough country. It a 1" block. It also comes with new U-bolts and nuts.
Do you have a good side photo of your truck?
It's not a 1:1 ratio for the lift. Because of the geometry, the 1.125" block gets you the 2" of lift. At least thats what I got and I measured before and after.
So the RC block was 1.125" ?
I'm actually thinking about milling this Zone block down a touch to net a 1.5" front lift, to keep some rake for towing and hauling. If 1.125" is truly good for a 2" lift, I can do the math and figure out how much to machine the block down.
Not really. I'll try to get one/some.
The RC rear block measures about 3/4" taller than stock. I like it because it now has a little but of rake to it. 38 7/8 front and 39 5/8 rear.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
