Hypertech programmer
Mine are at:
1-2 +3
2-3 +11
3-OD +0
My truck has a 5.3L and 3.73 gears, +3 & +11 are one below the max shift setting for my truck. I tried maxing them out but it didn't make any differnece in performance so I decided not to push the engine to much. My truck shifted from 1-2 5600 and 2-3 5200 rpm's stock, now they're both about 5950 rpm's.
Jim
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,020 Guests (See full list)
