Whatever parts I need will be going onto a 2004 yukon xl 6.0 4x4 2500.
Complete throttle body
Coils
Possibly stock air box, I have a magnum force afe cold box thing fir sale also but want a stock one.
Instrument cluster that is known to be good with trans cooler gauge
Possibly fuel pump but am not completely sure that is the culprit of my issues.
I have a ups account and will gladly have them shipped here given good price
Thank you!
