Off set on factory sle wheels??
Does anyone know the off set of the factory 2015 Sierra SLE 18inch wheels? Can't find it listed anywhere...
It is marked on the backside of the wheel on the stamping that has the wheel size on it.
Awesome! I will check it out and post it when I find it just in case someone else needs the info!
It's listed on the wheel as 18x8.5JX 24 so I assume it's a +24 offset...
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
