check this...
pacodiablo
Well the new body style is ok with me-I'm kind of neutral on it.  On the other hand, the new dash/interior layout looks awesome!  Check out the one photo of the dash-looks like a digital display for the ventilation controls is an option?  Cool!   :music:
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
