Sound system upgrade?
  • 2 months later...
Sonic Electronix if you can't stomach full retail Crutchfield. My last truck had over 2800.00 of equipment for about 1/2 of what Crutchfield had it for. Alpine, JBL and JL.....Just sayin'
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
