FS 2014 SLT Grille no emblem
This has been sitting in my garage for a while since I've been to lazy to post it.
Grille was on my truck for about 4,000 miles. Still in great shape no dents or scratches or anything, just replaced with a different grille.
This thing is going to be a monster to ship and will probably cost a fortune but I'm willing to split the cost with the buyer. I have the box my new grille came in that I can ship this one in
Asking $160 local pickup/meetup (Stockton, CA 95209)
EDIT: this is an SLE grill not SLT, i think they're the same anyway. unable to edit title
  • 3 weeks later...
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
