Heated Mirror
Is there a way to easily upgrade my exterior rear view mirrors to Heated?  And Polorized?  I would love to get them if I could find them.  My truck came with everything but that.  It is a 1999 Tahoe.  Biggest thing is the wireing there?
Thanks in advance.
Later,
Brandon
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
