Edge cts2 vs. Hypertech
It's the 5.3L v8. So I just lifted my 2015 Silverado 1500 6" on 35" tires and as known the speedo is off which makes my shift points off. I want to get the speedo back on track which then would put the shift points back closer to normal. I have a cold air intake cat back exhaust right now and figure with everything im gunna have a hell of a time getting the warranty to pay for anything if something goes wrong in the power train. But the Hypertech speedo calibrator would only do the tire size and the warranty might be saved with this and make the shifting and speedo good again but I want the extra power of the edge cts 2. Which I see it does tire size and my warranty is gone wit this but I'm interested in does it change the speedo on the truck? Or just on the screen of the programmer is accurate? Also is there a setting on the cts2 that's basically stick shift points? Would it still shift into v4 at times? Just needing to decide and get the speedo and such back to normal before I head off on a little road trip next weekend. Thanks guys!!
I had the same problem a month ago and decided to go with the diablosport intune I-1000. You can just change tire size and turn off DOD (AFM-turns off v4) without doing anything else. I just changed tire size and left AFM on.
Then you can turn it back to stock before taking it back to dealership. Gm week will to prove that me changing tire size in the ECM caused a problem.
And the intune I-1000 also comes with a few performance canned tunes.... 87 octane..... 91 octane.... But then you are playing with your motor then
Ok cool il have to look into the Diablosport. I like the just being able to change the tire size wit the other options but I really like the 5 inch touch screen. I really want to see whAt gear my truck is in. Lol I'm thinking all in all my warranty is shot anyway so I might as well get what I want. I want to get a little bit more power wen I need it.. Do you guys think I have a chance at any warranty on the power train? But any other programmers with screens on the fly tuning you guys suggest?
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 681 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
