Sign an E-Card for Jessica Lynch
Elwood
I wonder how she  will get it?  a long email?
My guess is that it'll be like a Yahoo Greeting or American Greetings.com Greeting.  She'll get an email with a link to it.  But I really have no idea, it just seems to me that that would be easiest.
