Ball joint & Control arms?
Does anyone know if there are aftermarket co trip arms that co me with replaceable greasable ball joints?
What about one of the lift kit companies?
I don't need them yet, but I will in time.
Maybe I should save for a lift kit and installation.
Rough Country 3.5" upper control arms are made for 3.5" of lift but work on any leveling kit. They also come with Moog ball joints. Moog also makes factory replacement upper and lower arms with greasable ball joints. You can find them on rockauto.com. Make sure you are aware if your stock arms are aluminum or cast iron.
http://www.roughcountry.com/gm-upper-control-arms-1278.html
Thanks. Is the easiest way to check with a magnet?
Yes, you can usually tell by the look too. Aluminum will be a silver colour and cast iron is painted black.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
