Express Van Towing
nick956
Howdy guys, so im about to purchase a 33foot bumper pull travel trailer and was wondering if my 04 express van with 5.3L and towing package is able to pull a trailer that weighs approximately 7,950 pounds? Also im interested in adding rear airbags to help alleviate sagging because even now when I add groceries or some weight in the back I will bottom out on dips and can hear hitch scrap asphalt. Thanks for feedback
Sent from my SGH-T999 using Tapatalk
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
