Martinsville
JonesNTN
Lots of Dodges though to in the top 10. Newman, Wallace, Spencer, K. Wallace, W. Burton and McMurray.
Go Jr on Sunday and DW on Saturday :thumb:
Jeff Gordon and Little E.
Only 1 ford in the top 10 and only 2 in the top 15.  :cool:
:D  :D  :D  :D  :D  :D  :D  :flag:
I was pretty happy with qualifying.  Three of my top 5 drivers are in the top 5.  Jr., Newman, & Rusty.  Too bad Waltrip and Park couldn't have gotten in there too.   :cool:
And Team Chevy Kicks some major tail at Martinsville 5 out of the top 10! ony 2 Fords in the Top 10. Man I guess the chevy guys are really scared of the ford advantage that they so proudly proclaim in their commercials, but manage to forget when it comes time to cry for some rules changes. :cool:
It was a so-so day.
The First 100 laps were Kind of a sleeper. :cool: Nobody was really Tradin'  Paint out there for that first part.
My man  Martin isn't doing as good as I would like to see. Hopefully He will turn it around and be a contender soon.
But hey, atleast my 2nd favorite got up there in the Top 5. That 38 team is improving every week and it shows. :thumb:
Oh yea!!!! :thumb:
I'm happy!!!!! :cool:
I bet.  :D
It was a good race today.  I wish Craven wouldn't have had his tire problem and slowed Jr. down.  I would have like to seen if he could have stayed up front.  :flag:
Well I missed the race but was glad to see that my favorite driver Bobby Labonte got a 2nd place finish...not as good as a win, but better then the last couple of weeks.  :thumb:  :thumb:
Considering how he was running at the beginning, close to gettting lapped, I'd say that was a great finish.  Good call for the team to go with 2 tires on that last pit stop.  :thumb:
I was hoping those last 2 cautions wouldn't have happened, we were on our way to seeing 4 cars duke it out for the win.  :cheers:
Yeah, kindof anti-climactic.  I was wanting to see Jr. and Gordon duke it out!
I was hoping those last 2 cautions wouldn't have happened, we were on our way to seeing 4 cars duke it out for the win.  :chevy:
Same here...I was getting ready for an "interesting" finish...but then the cautions came...
Great race though...  :thumb:  :D  :cheers:
Go 24 & 48!
pretty good race, marty isn't as boring as it used to be since they ground the turns, it was good to see a outside groove, I'm happy that harvick was able to get 16th with burnt feet.
My cable was out until right before the last caution that the leaders pitted on that resaulted in the restart with Craven's bad tire.  The Craven incident really bummed me, I thought Jr. had a chance.  But my question is about Gordon.  I need to see the replay to be sure, but I swear I thought his right rear was out of the pit box during the stop under that caution.  Like I said I need to see the replay, but that's how it looked to me at the time.  Am I the onlyone who thought that?  I thought for sure he was going to br penalized for it, but it was never even mentioned, which is why I say I really need to see the replay first.
