Can't Shift From Park
Mike Kosmo
First off here is the background on the truck: It is a 1996 GMC K1500 SLE with the 5.7L V8 at 204,XXX miles. The truck has a 4 Tuff Country suspension lift and 33" tires. Its been a pile of parts as Ive slowly been rebuilding it since I got it back in January (previous owner just was ill to this gem).
This week I replaced the steering gearbox, pitman arm, idler arm and bracket, all 4 tie rods, all 4 ball joints, and flushed the rear diff, new HD radiator and hoses, as well as plugs, wires, cap/rotor, and a fuel filter.
After all of that I threw on the Zone Offroad 3" Body lift. I am no newcomer to playing with trucks so I know how to install things, and I followed the instructions to the tee to ensure proper fitment. Everything went great at first.
Here is my problem now that everything is done. [No the battery wasnt unplugged the entire time I did this because I was rolling the windows up and down depending on the weather or if it was time to wrap up for the night] The shift stick (column shift of course) is stuck in park. The shift cable under the carpet is in good condition, plenty of slack and under the cab it is the same way. E-Brake works normally (tightened the cable too much, fixing that in the morning). Brake lights work when brake is applied. The "put the key in the ignition between off and on" trick also does not work for me as additional information. Never had issues with the shifter till now. Any ideas?
I'll bet it's the Shift Interlock,happened to my wife's Suburban.I just disabled it using a flat blade screwdriver to ''pop'' it off the ball then sliding it back.It's under the dash next to the steering column on the right side.
$_57.JPG?set_id=8800005007
Could be pressure on the parking pawl in the trans also,is it parked on a hill?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,002 Guests (See full list)
