9012 LED bulb????
XMR15
I know LED headlights have been talked about so much, but has anyone tried these 9012 LED bulbs?
http://www.xenondepot.com/9012-LED-headlight-kit-p/9012-led-hl.htm
I know 9006 bulbs work with minor modifications, however dont have the same output as 9012 bulbs. So I've been trying to find a 9012 LED bulb and came across these?
Just wondering if people are running them and having good luck wih them and if the light output is good. They say 2500LMS which is better than any 9006 bulb...what's other pp's opinions??
I actually just put these in over the weekend and they are awesome!!! i posted some pictures on the headlight and build forum
http://www.gm-trucks.com/forums/topic/156233-halogen-led-headlight-bulb-upgrades/
If you have any questions let me know!
If you go to the link you provided, the second reviewer is a K2 Sierra owner and gives it a poor review.
the rest of the reviews say the light output is great, but fitmint is alittle off. So if that is the case, I can modify them a bit aslong as the light output is worth the price.
How did your install go KKMitchell5?? Did you have problems with tabs and or the O-Ring?
I think the light out put is excellent. Mine fit great no problems what so ever. I did notice a couple things. The tabs on the led light are just smaller, the bottom tab on stock bulb is larger then the other 2 tabs. On the led the bottom tab is smaller then the other 2 tabs so you just have to make sure it is lined up properly so it fits snug as it should , and it does. Also with heat sink you just have to spread them out well and tuck them back good because the area to fit everything is smaller then it seems, but everything fits well under the housing cap.
Mine is: don't waste your time or money. LED bulbs are useless and provide laughable output at best. I'm sure others will be quick to say I'm wrong. Go look at lighting forums and you'll see. LED bulbs are as much of a joke as the PnP HID kits.
EDIT: Corrected spelling, etc.
Mine is: don't waste your time or money. LED bulbs are useless and provide laughable output at best. I'm sure other will be quick to say I'm wrong. Go look at lighting forums and you'll see. LED bulbs as much of a joke as the PnP HID kits.
+1! Any legit lighting forum blasts these things. I bought the OPT7 LED's for my Silverado at the recommendation of others here and the performance was awful. The cutoff wasn't terrible. But there was tons of foreground illumination and not as much further out as my H9 halogens. The foreground brightness actually blinds you and keeps you from seeing what you need to see, but many just see the crazy brightness and say they're great ignoring the control and light dispersion.. (Note this was with reflectors which others in the thread had)
I've since bought LTZ lamps and FZ-R projectors for a true retrofit.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 485 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
