door locks
Do you have steering wheel controls? If you do, all that can be set through that. Before i had steering wheel controls it would just lock/unlock in/out of Park
Something could have reset. Go through those menus and see what it is set to
I have 04 sierra 1500 when I remove key from ignition doors will not unlock have to open manually anyone have any idea.
Check your owner's manual. It tells you how to re-program your remote with 4 different options. Your doors should unlock as soon as you put her in park and lock when into gear. You can change it to only unlock 1 door or both, Have a look in section 2 of your manual!
