Sounds like one of our members
Jpshostr
No, this isn't me.  Try again!
I'm good cause i got a hot date tonight -- a date -- dinner with friends -- dinner alone -- watching tv alone -- alright, i'm gonna sit at home and ogle the ladies in the victoria secret catalog ------- sears catalog . . .
But was I right about the quote?
I don't know who originally said that.  I saw it and immediately thought of who bassdog said it was, Kansas.  Thought I could have a little fun with it at his expense.
Well, now you know.  I'll have to track down the simpsons episode.  All the pauses in there are where homer, lenny, & carl and giving Moe blank stares.  C'mon my fellow simpsons fans, help me out.
Homer in response to the 5 day waiting period for a hand gun
Homer - "5 Days?!?!?!? But I'm angry now"
Of course thats where it comes from.  Just that last name you typed after Moe threw me off, had no clue what you were referring to there.
It all makes sense now.  I'll slowly grasp it.
I had a good guess though  :thumbs:
Should we start calling Kansas " Kansas Syzlak"  ;)
Not a bad idea, I already call one of my friends Moe because he sounds just like Moe Syzlak and has the same luck w/ the ladies.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,323 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
