Tire Fitment
FBarber1
So I have been down through all of the tire (BFG KO2) topics that apply. I want to see if anyone thinks the setup I am planning to run will have any issues. The plan is to run BFG KO2 275/70r18 tires on the stock z71 wheels. The front valence is gone, and the truck has a 2" leveling kit. Anyone think I will have issues with rubbing or wheel fitment when I get the tires mounted?
Thanks in advance,
Frank
I am pretty sure you can run that size at stock height and have no rubbing so you should have plenty of room.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
