Line-x sprayed over tie down covers
You are correct, most shops do not spray over the access panel without removing it. But a lazy shop regardless of brand will spray the tailgate and access panel together. I just figured since the OP was having issues with the caps they might as well check the tailgate.
It isn't always about lazy, though... And the "training" is to prevent loss, not "do the right thing." My local Line-X dealers won't spray over the tailgate seal but they will absolutely spray right over the caps in the bed unless you ask them not to. Why? Because almost no one cares about the caps after the fact and MANY people will come back about the tailgate. So, Corporate "trains" them to not spray over the access panel.
I agree that a lazy shop / installer, regardless of brand, may well seal up the tailgate without a care. Especially if, in their direct clientele, no one cares about the gate and tells them to spray over it.
In my opinion spraying over anything that can be removed is laziness. Doesn't matter if you are trained a certain way or not. Removable parts should be removed so the job looks as professional and clean as possible. This is one of the reasons why I like my local Line-X dealer in Tuscaloosa, AL. They always make sure to remove the plugs in the bed, bed lightning and so on. Attention to detail is a huge concern for me especially when your paying $500-600 for a bed liner on a new truck.
I take a tremendous amount of pride in my work as I believe it is a representation of who I am as a person. When a business owner feels and acts similarly, they create relationships with customers like you have with your local dealer. If more craftspeople felt this way, we wouldn't be willing to buy the cheap imported junk versions so we can afford to buy ten of them over the years.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 928 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
