Audio system help
SaintDennis1
I love my sound system in my truck but it's too stock for me. In my old truck I had a system in it and I'd like to put one in this truck. I had 2 10" JL audio subs and I forget the name of the amps but being in a 98 it rattled my truck some times. I really really want to put a system in this truck but I'm not real sure how to go about it on this 2014. I want it to be clean, crisp, clear sound. I ABSOLUTELY HATE rattling from stereos and over powered subs. I just wanna know what you guys recommend on brands and boxes and if I should replace the stock speakers and what not. I'm
Looking for quality because I'm a perfectionist one could say. Anything would help. f132325b1409e6011affc23f7819b8a8.jpg
I have installed the Kicker self Powered Sub offered as a GM accessory. After playing with the setting, I can honestly say I am happy with it and how it compliments the rest of the system. I too, used to have aftermarket sound systems in my other vehicles, and honestly grew out of it.
BTW, great looking truck
