Light rear bumper.
I ran mine along the frame with zip ties, up the engine bay and connected it to a relay. Then from the engine through the firewall into a switch.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
