Apple Play for 2500
I doubt that it will be available as an 'official' upgrade from GM. But I see that there are third parties already offering things like phone screen mirroring, so perhaps a third party might offer a solution at some point in the future. From what I can tell, though,real CarPlay and Android Auto will probably require different hardware than what the 2015 systems currently have.
Not really sure I am interested in it if it is. My iPhone does just fine in my 2015 the few times I have used it for calls, music, etc. And I can't stand Siri for anything and have it shut off. So not convinced I am going to be missing anything by not having this in my 2015.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
