pics or info on 20x10 wheel with -12 offset
iridium1
Hey peeps I'm hopi g there's some of you out there running g a 20x10 fuel maverick or any wheel with a negative offset. I've hadany wheel and tire packages with negative offsets bUT they were all on dodges... this is my first SIERRA and I'm lost. Please help. Any info or pics will be greatly appreciated. Thanks in advance.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
