Mud flaps and flender flares
towdog333
I have weathertech mud flaps on my truck and wanted to install bushwacker oe style fender flares but with the MF on I can't without cutting the FF up which I'm not about to do.Has anyone on here have any suggestions , not sure if any flare maker makes one that fits around a mud flapBSW40956-02-Chevy-Silverado-Bushwacker-O
I have never seen flares that allow for mudflaps. That doesn't mean they aren't out there but I don't think so. When I put my flares on I had to buy new mudflaps.
You will probably need the flat style mudflaps which consist of a large piece of rubber material and some type of weight to keep them vertical.
