2015 Sierra SLT
Hey guys not to the site as I just bought a 1500 Sierra SLT. Goal was to buy a new truck and lift it. But as I found out last night I don't really have money for a lift. So I started looking into the leveling option. Question for those that have done it and are now running a larger tire. Are you guys seeing any issue for those with 3.08 axle? I was planning on running 33/12.5/20 Toyo A/T maybe Toyo M/T.
Congrats on the new truck. I have a 2" level but am not a tire guy so I will let somebody else chime in on that. Just wanted to say welcome!
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 926 Guests (See full list)
