Projector Mount
Aaron 68
Does anybody know where I could find the plastic mount in the headlight that the projector bolts to. I sent my lights away to get retrofitted and a few moths later I wanted to switch projectors. Upon taking apart the light I found out the guy used some plaster and just sunk wood screws down to secure the projector. I cant use these pieces now. FFS Just wondering if anybody know where to find some. Id rather not buy a pair of headlights just for those pieces.
Thanks
Who the F did you send your lights to? That is bullshit how they mounted your projectors. The brackets can be found at Fastheadlights.com
