2014 Silverado Tire Upgrade Question
I'm new to this site and I was wondering what is the largest tire size you could fit on a 2014 Silverado stock with 18'' rims. I'm considering on BF Goodrich KO2 265/70/18. Anyone running these tires on their Silverado or Sierra? I don't really want to go no wider in size but id like to have some more tire height.
Also anyone running 275/70/18? will they fit?.
If someone could help me it would be much help to me!
If you go on the Tirerack website, put in your year, make and model, it will show you what will fit.
275/70R18 will fit depending on brand. Some of them you'll have to zip tie the wheel liner back.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
