2015 GMC Sierra 1500 Low speed impact
I am a new member and proud owner of a 2015 GMC Sierra Standard box crew cab 4X4. The other day I watched out a second story office window as a Buick backed into my front bumper. I could see the box end lift up. The guy took off without a trace. I can find no visible signs of damage but was wondering if any damage not readily seen could result from such an incident. I know these trucks are tough but I've only had it for a couple of weeks and want to keep it new for a while longer!
If you cannot see any physical damage, cannot imagine there is any.
Would have to guess when the Buick hit, it pushed down on either the bumper or tow hooks which would bounce or raise the rear leaf springs.
Thank you for responding. I'm sure you are correct. I can't think of anything that could be damaged but I am surprized that the front bumper could withstand such a hit. I imagine the Buick has energy absorbing bumpers that would cushion the point of contact. I am sure that the GMC bumper would bend before any of the more critical structures. I had a friend that made heavy steel bumpers for his then new 1976 Ford pickup. He rear ended another vehicle with significant force and although he didn't appear to have any damage, his doors wouldn't open!
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
