Reverse and puddle light bulbs 15 Sierra
Can you change the bulbs in the puddle lights in a 2015 GMC Sierra. If so anyone know the bulb number and what brand did you buy. Same question for the reverse lights and cargo lights. I would like it a bit brighter. I can't find the part numbers for the life of me.
Thanks.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
