Exhaust Pipe Size
So I did a little Googleing and was told that the stock exhaust pipe on my 2014 5.3 Silverado was 2.75 inches in diameter, but when I tried to measure it today I was getting about 3 inches in diameter. Does anyone know the definite size? I don't know that I trust my measurement due to the fact that it is an angle cut pipe and I was trying to use a tape measure and not a caliper.
