New Honda Commercial
lauriet1
Did you read about how it was put together and that it took 606 takes to get it right. Amazing, you can read about it
:crazy:here
:banghead:
I've watched it now at least 6 times, and made my wife watch it too!!!
That is the coolest game of "dominoes" I've ever seen, and leave it to the Honda engineers to come up with it!!!   :thumb:
That is a very cool video.  :thumb: I just wonder how they got the wheels to go up the incline?
Click on here in my post up above. It explains it all. The tires were counter weighted with screws and bolts to  be able to do that. :thumb:
Finaly some enginers that are using there degrees :thumb:
I wonder how many takes they would've done before they scraped the comercial......
Three words....that's f*ckin awesome  :nono:
I think I would  :crackup:  :crackup:  :jester: if I was an engineer doing that... but the $$$ makes up for it  :D
Tom
