A/C guru's wanted!
Hi all, this is going back to a previous post but here goes:
 I had my A/C inspected today for a reasonable fee of 60bucks. ok, turns out that all the pressures are fine. I have an electrical problem. Apparently there is no power coming from the light green wire from the ac control  module to the ac relay.
Anyone know where this module is located? and how hard to get at???? When i push the button in on dash the little light does not come on. Hope this is all it is....may help someone else with the same problem.
this is for a 98 , i caint get 95..
  Document ID# 456487
1998 GMC Truck GMC K Pickup - 4WD
Heater Blower Controls Components
Name
Location
Locator View
Connector End View
Auxiliary Blower Motor
Behind the right rear wheelhousing
HVAC Component Views
HVAC Connector End Views
Auxiliary Blower Motor Relay, High
On the top of the auxiliary HVAC plenum, near the right rear wheelhousing
Auxiliary Blower Motor Relay, Low
Auxiliary Blower Motor Relay, Medium
Auxiliary Blower Resistor
Auxiliary HVAC Control Module
On the front of the overhead console, near the windshield
Blower Motor, Front
To the right of the IP, behind the IP compartment box
Behind the IP compartment box, on the HVAC plenum
Blower Resistor
On top of the HVAC plenum
HVAC Control Module
Part of the heater controls, in the center of the IP, under the radio
IP Fuse Block
To the left of the IP, near the left front door jamb switch
Power and Grounding Component Views in Wiring Systems
Power and Grounding Connector End Views in Wiring Systems
Recirculation Door Motor
Under the IP, on the HVAC plenum
Temperature Door Motor
Under the IP, on the center of the HVAC plenum
Underhood Fuse Block
In the left rear side of the engine compartment, on the fender
C100
Part of the engine harness to IP harness, in the left rear side of the engine compartment, at the bulkhead
Harness Routing Views in Wiring Systems
Inline Harness Connector End Views in Wiring Systems
C203
Behind the right side of the IP, near the heater motor, in foam wrap
C205
At the convenience center
C221
C230
Behind the right side of the IP, above the HVAC evaporator housing
C300
In the overhead console
C400
At the right rear of the vehicle, above the auxiliary blower motor
C401
D104 (4.3L, 5.0L, 5.7L)
Part of the engine harness, approximately 20 cm (8 in) from the A/C compressor clutch connector
D104 (6.5L)
Part of the engine harness, approximately 28 cm (11 in) from the A/C compressor clutch connector
D104 (7.4L)
Part of the engine harness, approximately 17 cm (6.5 in) from the A/C compressor clutch connector
G200
Behind the left side of the IP, below the fuse block, on the tie bar
G202
On the right side of the instrument panel, mounted to the HVAC plenum bracket
G400 (Utility/Suburban)
On the right side B pillar, near the door striker
P101
In the right rear side of the engine compartment, at the bulkhead
S102 (6.5L)
Engine harness approx. 6.5 cm (2.5 in) from the trans connector breakout, towards the starter solenoid harness breakout
S103 (4.3L, 5.0L, 5.7L)
Engine harness, approx. 8 cm (3 in) from the EGR valve breakout, toward the taillamp harness breakout
S103 (6.5L)
Engine harness, approx. 12 cm (4.7 in) from the starter solenoid breakout, towards the underhood lamp harness breakout
S103 (7.4L - A/T)
Engine harness, approx. 8 cm (3 in) from the EGR valve harness breakout, towards the ignition coil harness breakout
S103 (7.4L - M/T)
Engine harness, approx. 4 cm (1.5 in) from the fuel injector harness breakout, towards the taillamp harness breakout
S107 (4.3L, 5.0L, 5.7L)
Engine harness, approx. 20 cm (8 in) from the EGR valve breakout, toward the taillamp harness breakout
S107 (6.5L, HD
Engine harness, approx. 40 cm (15 in) from the EBCM breakout, toward the transmission harness breakout
S107 (7.4L)
Engine harness, approx. 18 cm (7 in) from the EBCM breakout, toward the EGR harness breakout
S110 (4.3L, 5.0L, 5.7L)
Engine harness, approx. 23 cm (9 in) from the EBCM breakout, toward the taillamp harness
S110 (6.5L)
Engine harness, approx. 4 cm (1.5 in) from the EBCM breakout, toward the taillamp harness breakout
S110 (7.4L-A/T)
Engine harness, approx. 26 cm (10 in) from the EBCM breakout, near the taillamp harness breakout
S145 (7.4L)
Engine harness, approx. 11 cm (4 in) into the EGR valve breakout
S147 (Gas)
Engine harness, approx. 5 cm (2 in) from the EGR valve breakout, toward the taillamp harness breakout
S147 (Diesel)
Engine harness, approx. 4 cm (1.5 in) from the starter motor solenoid breakout
S185
At Diode D104
S186
At Diode D104
S204
IP harness, approx. 10 cm (4 in) from C100, towards data link connector (DLC)
S212
IP harness, approx. 8 cm (3 in) from the inflatable restraint switch breakout
S217
IP harness, approx. 16 cm (6 in) from the instrument cluster harness breakout, toward the radio connectors breakout
S218
IP harness, approx. 16 cm (6 in) from the inflatable restraint switch breakout
S244
HVAC harness, approx. 8 cm (3 in) from the recirculation door breakout, toward the high blower motor relay
S268
IP harness, approx. 7 cm (2.5 in) into the HVAC control switch harness breakout
S298
IP harness, approx. 24 cm (9.5 in) from the instrument cluster breakout, toward the radio breakout
S307 (4-Door Utility/Suburban)
Rear HVAC control harness, approx. 10 cm (4 in) from the auxiliary HVAC control logic module breakout, toward the front auxiliary HVAC control module
S308 (4-Door Utility/Suburban)
Rear HVAC control harness, approx. 5 cm (2 in) from the auxiliary HVAC control logic module breakout, toward the rear auxiliary HVAC control module
S400 (w/Auxiliary A/C)
Auxiliary A/C harness, approx. 17 cm (6.5 in) from the blower motor relays, toward the blower motor
S410 (2-door Utility)
Front-to-rear body harness, approx. 37 cm (14.5 in) from the right rear door jamb switch breakout, toward the right rear door speaker breakout
S410 (4-Door Utility/Suburban)
Front-to-rear body harness, approx. 12 cm (4.5 in) from the right rear door speaker breakout, toward the right rear door jamb breakout
S440 (4-door Utility/Suburban)
Front-to-rear body harness, approx. 6 cm (2.5 in) from the convenience center harness breakout
S440 (4-Door Utility/Suburban w/o C69
Front-to-rear body harness, approx. 7 cm (2.5 in) from the crossbody harness breakout, toward the front dome lamp breakout
S441 (4-Door Utility/Suburban)
Front-to-rear body harness, approx. 5 cm (2 in) from the convenience center harness breakout
  Document ID# 456487
Thanks for the info asegrad 98,
 Im not sure how close the 98 and 95 are but it looks like that module is incoperated with the controls.
I will check it out this week.thanks.
I have been searching throught this problem but I have 2 confliciting diagrams......anyone have a wiring diagram for the A/C relay??? Need to find where the four wires go??? and colors please.
I was able to get a hold of a decent wiring diagram. It turns out that the light green wire is giving me all the greif. I pulled out the switch assembly in dash tonight. Bypassed the green wire and presto the clutch engages. Well, the fun, there is a small circuit board involved in the switch assembly, my guess is its the culprit. I will contact GM in the am and ask if it can be purchased separately? It would be easy to change, and hopefully not too pricey?
Any one come across this or have any ideas to share please do.
