2004 Silverado 1500 - Service 4wd?
Hey guys. Pulling into work this morning I looked down at my dash and noticed "Service 4wd" and none of my lights are lit up for my push button 4x4. I did some searching and found a bunch of different answers or problems it could be and was hoping to get some solid answers from you guys.
It's a 2004 Silverado 1500 ext cab and it just hit 153,000. I hardly use the 4x4 but then again have only had the truck about a month and a half. I used the 4wd just fine about 2 weeks ago though when we got some snow. When this happened I can't push the 4wd buttons. Well techincally I can, but nothing happens.
There was no noises or anything when this message came up. Is it a sensor or something simple? Thanks!
Edit: I shut the truck off and started it again with no fix. About an hour later I went out and started it to leave and all is fine again. So what's the deal?
My 2006 Sierra SLT 4x4 was doing the same thing off and on for several weeks, and my home scanner showed no codes. This was last year at about 144,000 miles. I replaced the push-button panel as per internet troubleshooting because it was cheap and easy, seemed to fix the problem for a day or two, then it came back. I ignored it because I wasn't needing 4wd then. One night on the way home from work, the truck made a loud crunching noise and the drive train started grinding like crazy, and I limped it home, but it would rev like crazy and only wanted to go about 10 MPH. Luckily I was only about a mile from home. Flat-bed towed to the dealer, they found almost no oil left in the X-fer case, which was stuck in 4-wheel low range. (I had NOT commanded that shift.) What little oil was able to drain out of the X-fer case was mostly metal chunks. The oil pump had eaten through it's housing and spit metal all through the case. There was a code stored but my scanner wouldn't see it. If this had happened out in the boonies on a logging road, where it is common for me to be, it would have been a much bigger hassle. Nothing was savable in the X-fer case, had to get a replacement.
Don't mean to scare you, just saying that there are small problems and then there are big problems, hope yours is the small one.
05 1500 here at 71k had same thing happened no lights on panel. Got it scanned and encoder motor needed to be replaced.
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 372 Guests (See full list)
