Which diff oils do u recommend
SAKO79
I like mineral based lubes for differentials. The friction plates seem to react better than synthetic lubrication and being that I have set up hundreds of ring and pinions for 20+ years I have in the last several years seen friction plates glazed over by synthetic lubrication.
RT
  • Replies 32
07Softail, not doubting what you say about synthetic gear oils causing friction plates to glaze, but I have never heard that before. How do you relate synthetic gear oil to glazing? Is this in a race car application? Are these used for street and raced on the weekends? Just curious because I have used Amzoil gear oil for years and never once had a problem with a differential, but mine are rarely abused or tow heavy loads. I use synthetics because they flow better when cold, have higher shear strength and are more stable as temperatures increase, plus they offer better fuel economy due to reduced friction.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 516 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
