Which diff oils do u recommend
SAKO79
I plan to change my rear diff oil and the dealer says 75W-85 synthetic. They also say I do not need no limited slip additive I have the g80 locking differential
The dealer here wants $21 a litre would you use the GM factory oil what would you use an aftermarket synthetic oil
  • Replies 32
I use Mobil 1 75w-90 in this truck and the last. It's full syn. I use royal purple in my quad.
I would recommend Mobil 1 or Amsoil
The Mobil 1 already has lsd additive in it, it won't hurt the differential if it's not required in the truck but it's already in the fluid
I believe I used regular dino oil in the front differential, and that's what GM recommends
front diff 75W-90 in cold climates
No anti slip in either diff
I haven't read the manual, but you might want to check if it has a recommendation for gear oil when towing. I think 75W-140 is the common suggestion.
I tow frequently and a high quality synthetic 75w90 is fine. I used 75w140 for break in of my other trucks diff after a rebuild
I just want to put a full synthetic and I looked up the g80 locker differential from eaton they recommend and say no friction modifier oil at all
I have Amsoil Severe Gear 75W-90 in my rear dif. Plan on doing the front sometime soon.
+1
AMSOIL Severe gear 75w-90 in both will work well. It has been in both of mine since 10k miles and I'm at 156k now. All is well.
    liddlera
    liddlera
  • Who's Online   3 Members, 0 Anonymous, 347 Guests (See full list)
