wheel question
With stock rims can i use 1.75 wheel spacers on a 14 Z71. It has a pro comp 2.25 level and a zone 1.5 lift. Will the wheels rub at full lock? Thanks in advance. Wheels are K2s 285/65/18
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 743 Guests (See full list)
