Relocating steering rack
I noticed with some lift kits for the 2014 and newer 1500's, the electric steering rack has to be relocated lower. Does anyone know why? Why not just use a fabricated knuckle with a higher mounting point for the tie rod ends, this would correct the angle without needing to move the entire steering rack.
I WAS looking at the RC 5'', until I read the install instructions, which include basically butchering up the truck and the steering system.
So far it seems like RC and ReadyLift require relocation of the steering rack. BDS does not.
Typically in knuckle style lift kits, you cannot reuse stock wheels. So a lot of kits will do what they can to utilize the stock control arms, and stock steering knuckles to allow use of the OEM wheels.
Also, it's just different ways of doing things. Gets to the same goal though.
Prolly cheaper to move the steering rack than to provide a new steering knuckle too.
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
