Has anyone color matched their window trim?
TXTruk15
wondering how that would look - I see lots of people taking off their chrome and putting on black window trim - am wondering if it would look good to color match - i have a summit white...
Depending on how much chrome you like to look at on your truck a color match could be a good thing or not. Chrome goes well with White and Silver colors. I personally want to take my chrome off and color match my black truck. If anyone out there wants to swap/trade me their 2015 CC OEM black window moldings and painted black mirror covers for chrome ones please PM me. I'm also looking for the OEM painted black door handles.
