New to this forum...from Calgary
Bogie
hey everyone....just found this board.... owned a couple diesels here, had an 87 Suburban with a 6.2  400,000 km on it...just replaced my 96 3500HD with a 6.5 in it with a C5500 D/A combo.  The 96 had 651,000 km on the original motor.
Looking forward to posting, and possibly even answering a question here and there as well...
